Suburban frame interchange
Jon_2399
Montana
Jon
Blazer
Just a quick question. Is a 1977 suburban frame the same as a 1988 suburban frame?
I'd like to put a 88 body on a 77 frame without a bunch of hassle. I do think the front frame horns are different for bumper mounting as the truck frames I know are. Is there anything else?
Strick
Dunn, NC
Harold
C20 Crew
Should work. There's a few differences as the one you mentioned but overall should be compatible.
HS
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
HS
Bigger difference is between 2wd and 4wd....big block, diesel and small block power have some difference in the cross member and motor mounts IIRC. Auto trans vs. manual transmission may also have a different cross member and mount. I want to say that a 3/4 ton Burb will have a little bit sturdier frame than a half ton one too....
Strick
Dunn, NC
Harold
C20 Crew
Seems that the bore for the body mount bushings are different 73-80 & 81-91. I had some Energy Suspension bushings (30 years ago) from an 81 up & they were too large to fit the mount on my 76.
HS
Yeah, use the body bushings that match the frame, not the body.
If the '77 front clip is not being retained, there will be some adjustments needed for the '88 radiator support to sit where it needs to.
Jon_2399
Montana
Jon
Blazer
The 77 is a 3/4 ton and the 88 is a 1/2 ton so 3/4 ton frame under a 1/2 ton body. 1/2 or 3/4 shouldn't make any difference. I think the transfer case shifter hole in the tunnel is even the same.
Blazerbiker
Rifle CO
Stephen
K5, actually a Jimmy since it's a GMC
504in
Do what you can to get them side by side and measure out mounting point by mounting point. You have a good chance of making it work easily but this will let you anticipate surprises better. It's not guaranteed all the mounts are in the same place or that the frame contours are the same to fit the later body. In the K5s they had a couple different floor layouts in the 70s and it's possible burbs did the same.
Use the body mounts that match the frame so the holes in the mounting brackets play nice with the mounting puck pieces.
The Suburbans didn't change frame contours like the K5's did. The K5 frame contour and mount locations only changed in '78 to accommodate the addition of a foot well for rear seat passengers.
Jon_2399
Montana
Jon
Blazer
Thanks for all the information. I knew that K5s changed frames in 78 as I've worked on several of them in the past. I've just never done any extensive work on a suburban. Here's a picture of the last Blazer I have almost done.
chupe1904
