steering box bolts
marks86
Latham, NY
Mark
12v Cummins
can someone tell me what the factory size of the steering box bolts or at least a picture of one
1986 k30 thank you
chengny
You mean the bolts that secure the steering gear to the frame rail?
I'd say 7/16" - but I'll go check.
marks86
Latham, NY
Mark
12v Cummins
yes, size, thread size and length is what I need
length of bolt is really what Im looking for
chengny
Oh well, they are not 7/16" anyway - they are 3/8".
Next time I go out to the garage I'll get an approximate length.
Wouldn't it be easier just to measure the mounting flange thickness and the frame thickness - add them together (and then increase that by 2 threads)?
chengny
I guess going by my eye is better than trying to jam a caliper down under the brake lines. They are 7/16" - 14 X 2 1/8".
This time I checked - see the parts dwgs below:
Oh yeah - they need to be Grade 8 bolts
marks86
Latham, NY
Mark
12v Cummins
thanks guys bought some grade 8 with lockwashers just to be safe
justink30
US
justin
silverado k30
I'm dealing with the same thing I just bought grade 8 7/16 14. @2 inches but can somebody tell me what I need for spacers? What size are they. And I know this is off subject but I have a 1980 k30 I need a fuse panel diagram. Can somebody email me one @ [email protected]. thanks I need help with wiring power windows, door locks , blower fan. Etc. My name's Justin
zciman
michigan
Michael
k20
chengny is right, don't forget the spacers. # 21 in the diagram. highdesertranger
About where the spacers go: , so the bolt goes through spacer and then through the frame and then into the gearbox?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
On my 84 K-10 the steering box sits against the frame, the bolts go through, and the nuts are at the end of the spacers.
Never could figure out why they did it that way.
That was done by a previous owner, for some reason.
Some people will use longer bolts and then put nuts on the outboard side, to act as jam nuts. I'm not sure if there would be any benefit to doing it the other way, besides making the install slightly easier (no bolts to line up while holding the gearbox in place).
geneandeva81
Colorado
Gene
What exactly are the spacers for? So confused
Camar068
10 yrs Air Force
crew
