srw to drw
87silveradok20
Ohio
Levi
Silverado k20
I want convert my truck to a drw. At the same time i want to do disc brakes. If i find a disc brake kit for a 14bt ff dually axle will i need anything else to convert my 14 bt sf to a dually. on the front i am going to run single wheels.
Konas new ride
Alberta
Gerald
Are spacers needed to clear the tire from rubbing on the frame when converting a srw to a dually? I was thinking the rear axle will be narrower for a srw truck.
I know a hub spacer for the front is needed to run the dually rim.
Anyone know any of this for sure?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
what axle are you going to use they had different width axles a lot of variables need to know what axle you plan to use.
single wheel 14 bolt 3/4 or 1 ton. spring perches are narrower on a 1 ton single wheel axle
dually with a bed used a dana 70 witch is wider
cab and chassis used a narrow 14 bolt
if you use the cab and chassis rear you will need 1 ton spring hangers the springs are closer to the frame on a 1 ton for added clearance for the inner wheel.
I have bolted dual wheels to a 3/4 ton 14 bolt but you should get longer studs to run the lug ring thing
diy4x.com disc brake brackets
http://diy4x.com/cart/index.php?route=product/category&path=37
87silveradok20
Ohio
Levi
Silverado k20
I dont know if i want to convert my truck to dually now, i wanted to only because i found a cheap dually bed. On the disc brake conversion will the conversions they have for the full float work on a semi float??
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I do not know if the disc brake brackets fit a semi float or not. I do not waste my time with the semi float axles. they are a good upgrade for a half ton if you can find one of the 6 lug versions.
68post
Indianapolis
Tim
454, TBD
68post
Indianapolis
Tim
454, TBD
You are so very welcome, glad to assist.
68post
Indianapolis
Tim
454, TBD
Please excuse this thread hi-jack.
I will be doing this to a C20 , did you have interference from the spring to inside tire ? Semi to full floater conversion ( 3/4 ton axle ), and changeover to dually.
I also need to convert from the small 3/4 ton brakes to dually large drums or disc brakes - any insight to those brake issues ? Disc the easiest route ?
I'll be going back to the "14 Bolt Bible" for alittle more insight myself , but it's not spelled-out too clear to me yet !
Thanks for anyones help on this , I may start a thread.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
if I remember right I had no clearance issue tire to spring. but the lug studs need changed to longer studs so you can run the ring for the lug nut tapper
semi floater to full floater is a direct swap
disc brakes on a full floater are easy but I would not waste the money putting discs on a semi floater. or putting dual wheels on a semi floater they are barley better than a 12 bolt half ton rear in my opinion.
diy4x.com makes nice disc brackets for the full floater for 70 bucks. then you can buy the calipers and rotors local to save shipping. if you want a park brake you will need Cadillac rear calipers and they are expensive
68post
Indianapolis
Tim
454, TBD
Thanks ! The full float axle would get the duals. What is the era of Caddy caliper to buy ?
19xx to 19xx ? ( I can find that with a search I'm sure , thanks for reminding us of it tho' )
The semi ain't so bad with a 9.5 ring gear and it's other shaft 'n bearing specs,( Dana 60 is only a 9.75 diameter), is it ? Mine has the large brakes on it too.
For what my trucks need to do a full float is the best for the job, but I'd like a semi in my '94 K1500 so I could put down more pwr , the front is a lost cause tho' !
THANKS Kleedus !
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
if I remember right 76 to 78 caddy rear calipers
68post
Indianapolis
Tim
454, TBD
Thanks, that is great info for this thread .
87scotty
Central il
Andrew
V20
5.7 for now
I am wondering about doing the oppisite i have a 1 ton dually 14bff i want to swap in my srw 87 3/4 14bsf spot
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
You can change the spring hangers and make it a bolt in deal. I done it on my 90 crew cab you can see pics and info in my 90 crew cab short bed build in the under construction forum page 18 or 19 somewhere.
square-up
