Square body on new chassis?
77Dmax
vt
Joe
The hydroboost is from the 05. I drilled new holes to mount it. The 77 had a normal booster. That was no big deal at all.
The steering shaft was a little more involved. I bought a universal joint from the local speed shop and had to weld the 77 upper shaft to the joint. The 77 double D shaft fit inside the 05 lower shaft- also a double D shape. Got it square and welded that. The collapsing part of the 05 shaft is still there, so maybe it is still kinda safe?
offroadunleashed
Saskatchewan, Canada
Adam
What about the intercooler piping?
77Dmax
vt
Joe
I didn't change them at all. The 05 core support is mostly in place. The rad, intercooler, shroud etc all are mounted as they left the factory, even the stock body mounts. I merged the two supports together. The first post or two describes the process. It was a pain in the ass, i spent hours trimming the two supports to fit together. If this was an LS truck i would have tossed the 05 support all together, but the duramax support is pretty busy with all the coolers and ecm mount. Plus I kinda remember the 05 radiator was way too big for the stock 77 support. It would have required a custom radiator that I didn't want to spend the money on..
thatgermanguy
