SOMEONE PLEASE HELP ME very appreciated
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
I know what it is its 17 over
bring it back down to 6 unplugged, then diconnect the battery for 15 seconds. re connect the dist, then the battery, then fire it up and see what happens.
Is the check engine light on while running?
Yes I'm on a phone prolly tell by how i spell huh internet got shut off so phone it is I took the radiator out and stared undoing all the belts I didn't do that test hand spinning the motor i just started to go for it I still can though and I think that's what I will do so I just take the distributor cap off is that what ur saying
Spelling issues we can deal with and understand, especially on phones, but punctuation is huge. Most of us read fast, and when sentences run together without a begining and end, we don't comprehend. We can live without the commas and apostraphies etc, but at least a period. Makes a huge difference if can do periods using the phone.
codesteez
Santa Rosa, CA
Cody
No never turns on wen I do the timing but shuts off if I had it at 6 I couldnt really drive unless down hill
Jims86
Patterson,Ca
5.7 TBI
Ok, this advanced timing is fighting something else.
unplug the vac line on the EGR valve, then take the small vac line off the back of the carb, and see if you can suck through the soenoid. you should not be able too. if you can, that may be the problem.(this means its sucking the egr valve open un commanded by the computer)
11 degrees is too far advanced.
codesteez
Santa Rosa, CA
Cody
Ok is the egr located next to what I believe is the choke control circle canister looking thing?
So I got it to spin holding with with hands ccw until the rotor turned the other way so then I went cw it maybe moves a 1/4 of an inch maybe from my mark undneath on the oil pan
Obviously my chain is okay its gotta something else
Yeah, if you're accurate on that test, that is very acceptable. 1/4 inch isn't nothing. you almost can't expect new to be better than that going back and forth. And the only way to check to see if you've jumped a tooth is to pull the valve cover, but if it's that tight, then it couldn't have jumped a tooth.
So that says cam/valve timing should be accurate. Now as Jim suggests, how about ignition timing? If you're dizzy isn't tightened down good and you gave it good rompin on, it can turn the dizzy and throw your timing right out the window.
codesteez
Santa Rosa, CA
Cody
I could at first but I followed were they meet up to three vac lines some kinda sensor right there in the egr vasinity and they weren't on all the way. I plugged them all the way in and now I cant suck through
Jims86
Patterson,Ca
5.7 TBI
Ok. Check the vacuum line going to the map sensor on. the firewall....make sure its plugged in and it good shape.
codesteez
Santa Rosa, CA
Cody
There's no such thing as a romp its zero to fifty in five minutes and tiny hills I'll drop all the way down thirty five fourty on the freeway. I mean 3 % grade I can't hold speed at all. Its not downshift and speed up its downshift and hope it doesn't loose to Much speed
codesteez
Santa Rosa, CA
Cody
That's all good no leaks its plugged in. There's another plug dangling not hooked up but The sensor is. Doesn't seem like theres anywhere to hookup to it has a green connector on it
Jims86
Patterson,Ca
5.7 TBI
Ahh yes, I believe that is either AC test, or lockup converter test.
The lack of power sounds like plugged exhaust. Hows about the valve down on the pass side exhaust manifold...does that eventually open up after the truck has warmed up?
78silverado
