Dutch Rutter
- Aug 13, 2013
- Independence, Or
- Joshua
- K20
I'm feeling pretty dumb here so please forgive my ignorance.
A short recent backstory:
I just had my 700r4 rebuilt again. The builder wired my Torque converter lockup to my 4th gear solenoid. So whenever the truck is in 4th gear, the converter locks up. It would also appear as though he disabled or removed the stock configuration. Because above 45MPH and in D the transmission will NOT automatically downshift nor will it unlock the torque converter. I can shift it down to 3 and everything works, then once back to cruising speed back to D. (I plan on starting this in a separate transmission thread separately, after calling the shop next week and seeing what he says).
The timing problem/question:
I was driving in D about 55-60mph, very low RPM (probably around 1500) 4th gear, torque converter locked. When adding any more throttle than part cruising throttle (no down shifting) I can feel the engine bog and then the pre-detonation spark knock starts. If returning to cruise throttle it goes away, If manually shifting to 3rd it went away, and I can not replicate the knock at WOT in a normal driving RPM range and gear.
I always run Premium 92 octane and never had this problem before the transmission changes, or at least I never noticed it because it would downshift and I would be at a higher RPM.
ANYWAY, while checking things this evening. I put my timing light on it, unplugged and capped the vac advanced (I have had it going to the ported port on my Edelbrock 1405) at idle I was seeing 30°BTDC.... I checked everything and tried it again same result.
Plugged the vac advanced back in and raised the RPM with the throttle linkage and I was seeing the same 30°BTDC.
Is it just my thinking is wrong or is that kind of high?
The truck idles fine, starts well (not a slow crank), has no run-on dieseling when shutting down, and otherwise does well.
Also is this worth chasing or should I just do the easy fix and keep it in 3 until I'm traveling 65mph+?
