Small Block Lifter Premature Wear
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Just for some information, Crower hardens their cam shaft to 62 to 64 rockwell C Also the lifters around 60 to 62. That’s with the premium cam cores. In compairson, HSS cutting tools RC is ~64, pretty hard. Use the zink, I like GM breakin oil, and all breakin oil is $$ but it is insurance. That is a BIG difference from what you measured ~ 50ish. Your oil and engine is contaminated. I would bet you cam is damaged enough where it needs reground. Remove the intake and use a dial indicator and compare the life to the cam spec sheet, A few thou may be OK, and the face finish must be perfect. In any case it's a shame, work, money.
Okay we dance around this anyway we want,just 1 lifter?I guarantee that lifter was too tight in the bore. Improper breakin,hardening oil, etc. would have wiped out more than just 1 lifter.
aaron hunsberger
