Side marker led lights dim when marker lights on
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
Hi there, so I swapped all bulbs to led.
Installed the led flasher , turn signals flash bright when no lights on. Once I turn marker lights on the side markers are dim even if I turn blinker on with markers on.
Do I need a resistor on the side marker or what can I do?
Thanks
RiverRat4
north coast ohio
r0d
vortec LS-2 5.3L
something Ive learned after throwing money at problems is always confirm your ground connections! Dimming lights under load sounds like a ground issue to me, but that's just an off the cuff answer.
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
I also have removed all ground cables and cleaned area
Thanks
what do you mean by DIM? you have no light or its barely lit?
are you saying they are never fully bright?
You may have gotten cheap LEDs.
you also may have LED 194 which are only going to work in either function but not both. they make ones that can do both. by both, i mean sidemarker and then alternates with turn signal. the way its done electrically is the 194 receives 12 volts on both sides of the bulb when it "flashes" and its grounded on one side when its just park lamp/sidemarker.
Then when you reverse the bulb, youll get the opposite behavior.
Jgonick
West Texas
Joel
This ^^^^
LEDs -light emitting diode- diodes only let current run one direction (unless they have been modified some how)
Rickf
Grafton NH
1974, 1954 & a 1937
My vote is for the wrong type of LED 194 bulbs. I had a similar issue and solved it with the "correct" LED's.
:cheers:
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
Yes it's barely lit, it is fully bright when I'm only using the blinker without any other lights on.
I tried uploading a couple videos of them but it's not letting me
1985C20FLATBED
