Side marker led lights dim when marker lights on
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
Hi there, so I swapped all bulbs to led.
Installed the led flasher , turn signals flash bright when no lights on. Once I turn marker lights on the side markers are dim even if I turn blinker on with markers on.
Do I need a resistor on the side marker or what can I do?
Thanks
RiverRat4
north coast ohio
r0d
vortec LS-2 5.3L
something Ive learned after throwing money at problems is always confirm your ground connections! Dimming lights under load sounds like a ground issue to me, but that's just an off the cuff answer.
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
I also have removed all ground cables and cleaned area
Thanks
what do you mean by DIM? you have no light or its barely lit?
are you saying they are never fully bright?
You may have gotten cheap LEDs.
you also may have LED 194 which are only going to work in either function but not both. they make ones that can do both. by both, i mean sidemarker and then alternates with turn signal. the way its done electrically is the 194 receives 12 volts on both sides of the bulb when it "flashes" and its grounded on one side when its just park lamp/sidemarker.
Then when you reverse the bulb, youll get the opposite behavior.
^Was gonna link that thread. Good info
Jgonick
West Texas
Joel
This ^^^^
LEDs -light emitting diode- diodes only let current run one direction (unless they have been modified some how)
Rickf
Grafton NH
1974, 1954 & a 1937
My vote is for the wrong type of LED 194 bulbs. I had a similar issue and solved it with the "correct" LED's.
:cheers:
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
Yes it's barely lit, it is fully bright when I'm only using the blinker without any other lights on.
I tried uploading a couple videos of them but it's not letting me
squarebfan
Sandpoint, ID
Preston
k20
6.6 duramax
:cheers:
What type of led bulb is it that I need to get?
Rickf
Grafton NH
1974, 1954 & a 1937
I haven't been able to find out what/who's bulbs I used and I don't have the truck any more. I kinda remember the bulbs had a built in resistor, not sure it was a few years ago.
You may try to put the bulbs in 180* and see what happens.
Dejure
Eastern Washington
Kelly
C15
SNORT
I had to check to see if I wrote this a couple days ago.
(0) All LED's, except the front parking lights.
(1) Park and marker lights come on when I pull on the light switch.
(2) With the headlight switch off and the turns on, the turns work AND the front markers indicate I'm turning.
(3) With park-headlights on, when I turn the signals on, the right works, but just the left rear works. The front turn INCANDESCENT bulb just barely glows.
(4) Swapped to LED on the front and the lights work, but. . . .
(5) Check socket ground to actual ground on the battery, and I get ohm overload (meg ohm - infinity).
Today, I'll try a temp ground, then track down the left front marker, park light and turn ground spot.
83Stepper
Massachusetts
Chad
SNORT
Open or floating ground in the circuit. If the right rear doesn't work, I'd start there. Could be a bad bulb, bulb connection or ground issue. Make sure you've got grounds at all 4 corners and they go back to the bulb socket.
Dejure
Eastern Washington
Kelly
C15
Like I mentioned in my post, I get a megohm reading on from the bulb socket ground to the negative lead on the battery.
Too, the ONLY problems appear at the left front marker and turn-park lamp.
Based on the above, my first place to look is ground, starting with a temp ground circuit, to solve the issue of high resistance between the socket and battery ground. THEN I'll track down the ground points, test them and clean them, adding a bit of silicone [high dielectric] grease to minimize future oxidation.
Thinking on it, I may buy new sockets and add load resistors to them, to accommodate the use of LED's. Add to that, a switch to plugs and receptacles, so the sockets can be changed easily. And, again, with the anti-oxgen grease.
Waterproof connectors would allow quick swaps between LED's and incandescents.
cahillasher76
