Show me your SBC fuel pressure gauge/regulator setups.
I double checked- I only have two hoses- and the Edelbrock 1721 that I have in hand is the same. Guess I just need to make sure that the return line is corked off- it's likely hidden up in the frame rail.
if you have just that pump and you find you DO have a return line and thus a 3 port sender on your tank, i would drop your tank or lift your bed and replace the sender(new sock and seal off that unused return in that case and then you can put new rubber line on the part where it goes from metal to the sending unit with short hose lengths so you dont have your new pump sucking air
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Here is a pic of the 454 holly 4160 converted to a 4150. Much better then the Carter AFB.
Craig Nedrow
Washington State
K10, K20, C20
Proof is in the pudding...
better i would say is more about how you use your vehicle and what you want to do and what you value
Edelbrock is simple but that very fact is a helpful and selling point to a lot. (me one of them) not having any gaskets that can leak fuel below the top of the carb is quite good and it can go far for safety if you especially had a infrequent use situation for the vehicle
But set and forget seems to be a phrase not associated with holley(Ive heard) but ive also heard of the endless opportunity and precise changes one can do, and the fuel rates and the enrichments (esp with forced induction) that there is no other to the great holley
and then if you fear what lurks in the dark some wise spirit may come out of his oldsmobile and start hurling the great reality how 1 carb design operated a lot of vehicles for a lot of years where it had unbeatable driveability and mpg with the ability to work with all the countless emissions doodads
to that end, the qjet, on the emissions stuff...
assuming you can find the spec, the part, the adjustments, and you can have yourself a CARB approved truck when you started with a engine swapped parts rolling chassis lol!!
Craig Nedrow
Washington State
K10, K20, C20
Easy Taylor, just stating a fact in my case. Also that holly was setting right in my cabinet, so little outlay. You get used to a (put here,) certain thing, for me I have been working on holly's for fifty years at least, it is formular and comfortable. He asked for pictures, so I posted to help him out.....
I apologize, what I said I could see being aggressive in tone. I was , if it means much ,being more chatty than argumentative. Sometimes the difference is hard to tell LOL
Im not gonna attempt to restore it any time soon but you may appreciate this old thing :)
legozombie
Colorado
A
5.7 350 v8
I have an M4ME Quadrajet on my 350 5.7 sbc. Here is the fuel pressure gauge with a quarter turn shut off valve for troubleshooting. I got the idea from a significant figure named "lars" over at the corvette forums. My fuel pressure was a little over 3 psi when running and a little over 4 psi when shut off valve was closed/engine not running.
Gators01
