serpentine upgrade, fan almost went through hood. Anyone done this with a flex fan?? pics inside
Dave M
Banned
Australia
Dave
its reverse rotation. due to serp setup.
OK, not real familiar with what goes on with fitting a serpentine set-up, l assumed you just swapped over the pulleys, and the water pump still rotated clockwise from the front?
bluex
Spartanburg SC
C15
Since you're in need, look up cold case radiators. They make a real nice setup with fans an a shroud as an option. They work very well, I'm a dealer if you'd like I can see what I can do on a setup for you.
Alternatively I have a stock radiator an shroud with a 2002ish jeep grand Cherokee electric fan. It works great an has no problems keeping the truck at/around 195 degrees. The shroud is most definitely needed regardless of the direction you go. Controlling the flow of the air an ensuring it goes through the radiator is as important as the amount of air you get through there....
RoryH19
Rory
R10 Silverado SWB
Didn't read the entire thread but I have a serpentine setup on my 87 r10.
Took everything from a 90 burb. had the reverse fan/clutch and water pump too.
Have been running for 5 years no issues. I did put on a new water pump at the time so wouldn't have to worry about leaks. Also new rad hoses. The bottom was the same. The top one was for the burb. I also have A/C, R4 style.
I can take a pic if you want to see the setup.
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Thanks Rory, Im just gonna go with Dual fans.
HOTFOOT
northwest ct
michael
gmc k3500 srw
Looks like the shaft on the water pump broke the bolts are still bolted to the hub on the pump so the bolts did there job
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
I wouldn't use a 3 1/2" spacer, anything out of balance will put a lot of strain on the water pump shaft.
Catbox
Peter
C20 Silverado Camper Special
We have been running these Flex A Lite fans on our big block for months now and they have no issue keeping the engine cool.
Even though they do not cover the entire radiator, they cover plenty of it and move tons of air.
Carb'ed Vortec 350
Oh the carnage! That sucks. I like @Catbox 's fan setup
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Sorry that happened! As was mentioned above, your water pump shaft sheered off, (at the channel that the bearing runs on) due to that huge fan spacer. I had the same thing happen about 4yrs ago, and I learned the hard lesson: Don't use a fan spacer.
IMO, if you don't go with electric fans, you'll want to re-create an OE style set up, which will include a factory shroud. You'll want the fan blades sticking about 1/2-3/4th of their depth "into" the shroud opening. The rearmost section of the blades should be out of the shroud, in order to provide proper air flow off the blades.
a 36 (34?) 4 core radiator and a small pusher fan on your trans cooler would help too, yes? :)
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Im just going to go with dual fans. 4 core radiators are to expensive to be replacing. Not
going to take any chances from here on out!!
Thanks everyone and AuroraGirl :cheers:
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
3 core all aluminum is only hair over 2o0 bucks from champion cooling
rodfarm
