Chris64
- Sep 16, 2024
- San Diego
- Chris
- K20
I just broke down the disgusting seat/mouse house on my 1974 K20. I'm pretty sure this was the original seat/cover. If you leaned on it your hand would go through it.
The frame was in spectacular shape so that's great.
First question. Is it worth reusing this foam (back only, bottom was beyond repair)? It doesn't seem like it's in bad shape but the parts that were exposed are prone to flaking if you poke at them (that area low center in the pic).
I've been looking for foam and a common complaint is it's too stiff or sits you up higher. Any recommendations? Cheap is always good too.
Also is there a conversion kit to make the fixed seat foldable? I've looked around for a donor seat and they're hard to find in my area (all SB parts are).
I found this and it seems like a pretty good idea. If I went this route, I'd probably reinforce the area that was cut away and put in a stud on the lower screw to make it stronger (and a locking mechanism so it doesn't fall forward. I'd really like to get the stock plastic side covers so it looks stock so I was hoping there might be a weld-in kit. How could this not exist?
