78C10BigTen
- Apr 12, 2017
- pennsylvannia
- Ted
- C10 BIG TEN
Oof , got me there ******
Yep. $50 of beer today don't go as far as it used to!
Irony here is, ive been telling my friends,
"One day i wanna put togethet another naturally aspirated 327"
I once had put together myself a 327 long journal, bored .030 over, with + dish pistons decked head, forged internals, and vortec heads.
I wanted to make a fire breathing, 8000 rpm motor that ran on 100+ octane
I estimated c/r would come up to 13 or so with that setup.
Like a young gun, i sold it to a friend, he threw it in his 23 bucket with a th400 and a 1000+ cfm carb, he sent videos.... that was a flat nasty , DANGEROUS motor.
Id like to do that again.
Or in my case a big bottle of jim beam devils cut!Optionally 50$ will get you a bottle of johnny black label.... just saying
Yes, 3970010 is 68-69 327 or 69-79 350. Bottom line, it's a 4.0 bore large journal block and came in 2 or 4 bolt mains, 2pc Rear Main.Yeah, it's incorrect. Iirc, my '69 327 is the same casting number.
I'd run the suffix #'s. It could be a 350 that someone put that intake on. Be sure what you got.Now i just need to decide what to do with it![]()
The numbers in front of the passenger head on the block?
Those yielded no result for a 350 or 327
Post up that serial number on the flat in front of the cylinder head. The casting date on the back of the block would also be helpful to go with that casting number. Between those three numbers you should be able to figure out exactly what you have.It'll get taken apart sometime during the winter, ill confirm what it is then
