Blackbeard44
- Jun 14, 2020
- Washington State
- andy
- K20
- 6.0 LS
not a fullsize square body truck, its a compact version.
1989 S10 2.8 liter V-6 TBI w/5speed trans
when cold starting it cranks for about 2 seconds than fires up on the high idle (RPM'S unknown) where it stays for approx 1 minute, runs nice and smooth, as it starts to return to normal idle it goes through a phase where its starts running very rough and smells very gassy at the tailpipe, it surges like it is searching for idle for about 1 minute than it clears up and runs beautifully.
somewhere in between high idle and regular idle it looses its tune.
recently bought the truck from a parts store lackey that could not get it running after a motor swap and proceeded to throw the kitchen sink at it and replace every sensor, distrubutor, injectors, fuel pump, temp senders, MAP, the whole works.
i suspect a vacum leak but cannot find one, I can live with how it acts, but would like to make it run properly. whats your suggestions, i think later today I am going to verify the throttle position sensor is working properly, other than that I'm stumped
