Replacement wiper arms
Ewhitaker0020
Go to JEGS.COM. I got replacement wiper arms for my 1976 K10 for 14.95 each. I'm sure they're not that expensive for an '84.
I just checked and they don't have one for my truck. Also, I'm wanting a different style of arm, not a direct replacement.
Sent from my SM-G950U using Tapatalk
Ewhitaker0020
Have you received these yet?
I have received them, I plan on trying to put them on tomorrow. If the splines line up I think they'll work.
Well?
I bought a new set for the 87 year off ebay as someone suggested in my post on the subject. 6/10 quality. The sprayers look weak(I dont have a working system, wont bother making it work) and the arms are too... weak. Lifting up with a bit of pressure past its stop point bent it easily. I want an arm thats going to hold good pressure so it can handle ice and snow, its main enemies. They do look nice tho, and having the arm with the point worked, would LOVE the j hook.
Scott91370
Burleson, Tx
Scott
Sierra1500
I've started looking into changing the arms as well. They're so small and appear to not cover the window very well. I'll be keeping an eye out here for different kinds being used.
Ewhitaker0020
I'm sorry I haven't had time to put the ones from the 01 jeep xj on yet. Maybe I can try to do one tonight. It's been raining so much here and I don't have anywhere inside to work.
Ewhitaker0020
I can finally confirm that the wiper arms off a 2001 jeep xj seem to fit and work just fine.
I put them on tonight, but will be able to try them out tomorrow and make sure they actually work well. I had to take a mallet and gently tap them down, but they went easily. The biggest difference is the way they sit on the windshield. They don't sit flat when down. Instead they're angled a bit. It looks worse from inside the cab than the picture makes it look. But a dry test makes me think it will hold the wipers down to the windshield better.
Do they fold up or are they like old wipers where they just spring hold down
Ewhitaker0020
They also are at an angle instead of being straight across. I'm going to try and bend then so they sit a little more flat
goodwrenchca
