Repainting 390 Oil Pan with Purple Power De-Ruster
davbell22602
Bunker Hill, WV
I Dont
Have
One
Instead of using a drill/wire wheel you might get better results using a 4-1/2" angle grinder with a wire wheel. You woulda had a lot less rust left I believe. But yeah that purple stuff looks like hell when it dries but that's the way it's supposed to look, it wont ever look like an even coat of paint or primer. When I get around to doing the rest of my axle I'll take some pics, mainly use it in places my grinder wont reach the rust.
So I'm ok to skip the the 2nd coat or go ahead with the second coat? I'll have to buy the angle grinder. Thats something I dont have yet.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
You can skip the 2nd coat, I never do 2 coats. Usually while I'm putting it on a part I will dab more on the worst places as I go but yours is probably good as it will get. I would do 2 coats of primer, light sand the 2nd coat to smooth it out some then paint.
davbell22602
Bunker Hill, WV
I Dont
Have
One
ok, Will go prime 1 coat and post a picture.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Here's pictures after 1 coat of Rustoleum Engine Primer.
What the hell? You leave it on? I thought it stripped it to bare metal? :think: I totally misunderstood this product. :slap:
Is there a reason you didn't try the electrolysis thing on it?
davbell22602
Bunker Hill, WV
I Dont
Have
One
No, The Purple Power De-Ruster stays on so you can paint over. Just like the Rustoleum Rust Reformer.
Dont wanna take the chance on dumping toxic waste on street in a housing development where there's a home owner ass. is at.
I might end trying on a 4bbl intake though and taking the chance of getting caught.
Ok, I thought it had to be washed off or something, like htat Naval Jelly stuff. What color are you going to paint it?
How many coats of primer?
Are you going to sand the primer coat after it's dry?
And better paint adhesion too. :waytogo:
davbell22602
Bunker Hill, WV
I Dont
Have
One
Not sure if sanding it to smooth it out will make a difference cause it still has rough texture to it on the surface. Might be able to fill in that rough texture surface with couple coats of engine paint.
Is there a one piece gasket for that pan also?
willfill
