Rear shock mount problem
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
The '88 Burb was riding a little odd the other day. Checked it out and noticed that the upper shock bolt had ripped up out of the shock mount. Anyone else experienced this?
Dougnsalem
Something tells me this is gonna be a busy thread....
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Many many times in the early 80's with my '78 Heavy Half 'Jump Truck'. Lots of ways to fix it. I ended up fish plating the section of frame where the mount was getting torn off.
ajd89
Central Michigan
andrew
Preciate that, but... "Does not fit K30's or Suburbans."
Wow your right i just assumed they would be the same as a k10 or 20 my bad. Still could make something similar im assuming? once mount is repaired
radio2000
South Carolina
83 and 88
I thought it would be the same as well. I was getting stoked.
ajd89
Central Michigan
andrew
I’d say I’m sorry, but I’m not. What a chinsy looking piece of crap for $40. It appears they spent seconds engineering that turd.
Yea i was just gonna make my own anyway someone had made some i seen that had 2 bolts on each side and a cut out for the shock hard to explain and i dont know where i seen it. Same idea just better then those. So why womt they work on burban?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Idk maybe there’s a body mount there. My burbs gonna have 1 ton shock mounts on the inside.
radio2000
South Carolina
83 and 88
These look nice, but this is below the original mounting point, right?
radio2000
South Carolina
83 and 88
This is how mine is mounted, but the failure is much worse.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That looks in about the original mounting point.
sparky77
