Radiator Leaking
Mango
JacksonWyoming
Gil
Radiator leaking only two years old ?? Just noticed it a few days ago, all hoses tight no leakes, leaking on drivers side! I installed a power steering cooler and maybe the culprit? on how the attachments are attached to the front my of the rad ??? PITA
Mango
JacksonWyoming
Gil
Not the Power Stering Cooler
fast 99
Spokane, Washington
Radiators are junk nowadays. But if you used the through rad things it's probably worn a hole. Especially if foam isolator wasn't used
Suggestion is those plastic pins will abrade tubes in the radiator from vibration. I agree radiators are low quality today but should last more than 2 years. When radiator was replaced was coolant and if necessary, system flushed? What area is coolant coming from? Are all grounds intact?
Mango
JacksonWyoming
Gil
@fast 99 Yes Coolant flush, No Plastic pins were used Power steering coolen in the front of the AC Rad
Purchased from LMC truck $300 with oversize charge and shipping Loking at Rock Auto much cheeper
LMC specs 21'H
Rock Auto 19" H
Both 28-1/4 W x 1-1/4 W
fast 99
Spokane, Washington
Height change might require different radiator mounting brackets and possibly shroud.
Finkaire
Finkaire
California
Loren
Silverado c10
Had mine re-cored recently after two attempts at replacements.
Sit down before you hear the estimate
Mango
JacksonWyoming
Gil
Well i tightened the intake hose clamp a little, did not see that it was leaking, Have not noticed it leaking ???
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
So the hose was leaking because of loose clamp, not the radiator??
I had almost the exact same thing happen. Noticed coolant under the truck. Couldn't see it leaking from any of the hoses so I thought the radiator had sprung a leak. Decided to check the hose clamps on all of the hoses first... lo and behold, clamp on the water pump was loose and it was leaking from there. Tightened it up and no more leak!
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Corbin clamps for the win. I prefer the wide band style over the wire style, but it beats those damned screw clamps backing off.
Camar068
10 yrs Air Force
yeh once you find a good set of them, go back and buy a few more. Auto stores are flooded with the ones that jump threads.
Mango
JacksonWyoming
Gil
Not the clamp started to leak again bottom left drivers side, could not see the weeping leak? Pulled it out and installed a NAPA Rad from China what could go wrong?
The Rad i pulled was from LMC $300 with shipping and taxes only 8 months old WTF? Hope they have a warranty?
Not leaking yet
I like to get my clamps from AG supply places, for spray equipment. You can still get the real high quality stainless ones that are even made in the USA. I used to buy them by the box at NAPA, they were the nice, sturdy, stainless Breeze brand. Until I got a box that was not Breeze and lower quality. Haven't bought any since then.
philly4424
