Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
First I found a 6 blade GM fan which I am now using. I also replaced the clutch fan and now have a Hayden HD clutch fan.
Even with all this and the truck running I still cannot get my truck warm enough to get the thermostat to open!!
I'm honestly out of ideas and will be putting a place in front of the thermostat neck to redirect airflow around it.
** Edit **
Just did some reading and it seems there could be a different sized water pump pulley and crankshaft pulley. Which could cause a fan to spin to much or too little.
Was suggested to block flow to the heater core and this made no difference. So I put a piece of plywood in front of the radiator and this did in fact help.
Once I secured the plywood the temps went up as normal and thermostat opened and coolant flowed. When I did this I found that there was far less air flow all together as well as less air being blown on the thermostat housing.
What temp thermostat are you running. I had the same issues with the 180. The only way my truck runs good is with the 195. Maybe if you lived in a dessert you could use the 180 but north of the border even the Northern United States, I would use the 195
