question on 85 C10
web365ster
california
cross
Chevrolet K5 Blazer
SBC 350 GM Performance Crate Engine
Hi all
Sorry if this is not the right forum
Which set of lights should be low-beam versus high-beam?
I thought low-beam would be the upper pair?
Come to think of it, I've never owned a vehicle with stacked lights like this before!
Thanks.
SquareRoot
85 doesn't have stacked lights.
SquareRoot
Maybe yours does not but I am sure they were doing that in 1985.
I stand corrected. Didn't realize there was an option. Thanks Redfish.
Redfish
Prairieville, LA
Andrew
V1500
You actually surprised me on this one! I know you know more than I do about these trucks, I sort of assumed you misunderstood his question.
SquareRoot
I have an 85. I know there are a standard and a deluxe grill but I didn't know the the rpo v22 was an option that added quad lighting. I'm always open to learning something I didn't know.
Finkaire
Finkaire
California
Loren
Silverado c10
Dim low beams on top. Cars behind you leave a shadow of your truck. Working on a solution, check these out
CheemsK1500
K1500
From the factory it should be low beams on top, though you can invert the harnesses and lights to make the bottoms the low beams (I don't know why anyone would actually want to do that though). Also be mindful of the difference between top and bottom. The light itself is the same size, but the number of terminals are different. Top has 3, bottom has two.
CheemsK1500
K1500
If you go the LED route, make sure you put resistors behind them, if they aren't included in the retro-fit kit. Older 12 volt systems don't take kindly to full power LEDs.
Finkaire
Finkaire
California
Loren
Silverado c10
Headlight Experts is what I was considering. Supposed to be able to simply plug and play with no modifications.
K5ride
Apple Valley, CA
Steve
C10 Stepside
I'm running the headlight expert LEDs on my 75 Stepside. I had to call them to get the orientation right as their video is incorrect. I'm very happy with them. They are a very clean, white light and are super bright and clear. The lenses also have the fluting on them so you don't blind oncoming traffic. Yes, they were plug and play.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
bhumps
