Fuel caps instead of doors is 77' and older . My 76' had caps, my 79' has doors . The front disc brake pads are the same C20/C30 on 2 wheel drives . There were 8200 GVW and 8600 GVW C20's , and they both used corporate rear ends . This deal looks like a complete "rebuild", and is not an actual C30 dually . By the way, the 1973 duallys had vacuum power brakes, (I had one) and the hydro boost systems were started in C30's in 1974 . Return fuel pump systems (for vaporlock) started in 1976 .
In the photos above you do not have a "camper special" (C20 or C30) since I don't see any rear sway bars . The duallys had rear sway bars even without being a "camper special", and used the Dana rear end . The dual wheel "cab a chassis' trucks", also did not have the rear sway bars unless it was special ordered to become a motor home (Open Road brand among others)
