quad shock brackets
The shock that uses the optional frame bracket is a longer shock than the one in the standard position.
Green79Scottsdale
G.R. - MI
Bob
Seems to me the fact they are NOT running parallel to each other would be the major contributor to broken lower mounts, rather than the fact there are two of them.
hirschdale, when you run yours are they set up parallel, or skewed like the factory set-up?
hirschdalechevy
norcal
rich
k-30
I have had them both ways , on my old 78 I had the trailmaster side by side upper mount , stock lower , (dont know if they make that mount anymore) and I dont recall bending the lower mount with that set up.
On my 77 crew I have the factory dual shock mount (staggered) with the stock lower mount. I though I had my custom mounts on my crew but I do not , (I am getting old and losing my mind). My boy said I broke that front end in my 77 step side jumpiing it quite a few years back .
Anyway , I have had three trucks with the factory dual setup and have bent the lower on all three off roading. I will not be putting the custom lowers on my crew because the dauls are just for looks and it really never goes off road , did'nt build it for that.
Its really easy to make the lowers though , just get a piece of channel that fits the shock bushing width and cut it about 5 to 6 inches long , gig it up at the stock location and angle it right with the shocks mounted at the upper , then tack it. Then cut some 1/4" steel triangle's for each side of the channel , weld it all up , good to go forever.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
What if you just weld on a third piece of metal to the axle on the outside of the second shock(closest to the diff)so it has its own mount on the outside and they both share the center piece
Why would that matter? Having one that is more upright doesn't make the tilted shock try to move in another direction. They are both free to do their own thing. But the one mounted more upright is more effective at damping, so that might have something to do with overwhelming the lower mount.
87scotty
Central il
Andrew
V20
5.7 for now
Just letting you guys know I have ran a lot of dual shock setups on my square's and if you are lifted and wheel off road a lot I have destroy'ed all of the lower shock mount's when running duals. If you are mostly on the street and light off road you will be fine , (just giving you the heads up).
I always use channel , (the same width of the skock bushing) and weld that to the housing in the stock location and gusset it on both sides , then you bolt the shocks in line of each other , never a twisted or broke mount again.
I will try and snap a pic if you guy's are interested and its not hard to do if you can weld.
Definetly would like to see what you've done
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I'd like to see it still too. I finally got my lift in today so ill be needing some shock mounts pretty soon lol.
I put lift springs in front and blocks in the rear and when I got done, I found out that the burb has the "cali lean" haha granted I don't have my motor in, but its only a small block it wont make the new springs settle in as far as it needs to go so the burb is level. I think my rear springs are sagged out:whymewhyme: I hope the motor sags the front end down enough to where it looks somewhat acceptable until I can get rear lift springs..
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I thought I would post here instead of making a new thread. I’m getting a factory dual shock setup off a parts truck, and I need to know how to go about ordering shocks. What valving do I need ? I’m assuming the shakil valving is different for quad shock vs dual shocks.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Depends what you're buying. Delco makes completely different shocks for quads. Monroe just adds a second shock to the stock single. If you're going for something more sophisticated you'd have to look at the manufacturers recommendations.
RoryH19
Rory
R10 Silverado SWB
Not sure if I followed procedure but I just made sure the shocks were long enough.
I have a 3 inch lift on my k5. Basically I used this for the standard shock and made sure the second shock could handle a 4 inch lift.
I used skyjacker black max all the way around even the steering stabilizer.
highdesertrange
kalifornia
mike
k30
for the shock length you must take into consideration total drop as well as total compression. both numbers are equally important. highdesertranger
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
That is 100% true. I ordered the recommended set for the lift on my old Suburban, and they unbeknownst to me pretty much became the limiter of droop. I drove home with a shock in two pieces one day. Lol
RoryH19
Rory
R10 Silverado SWB
According to Gabriel's site, the "short" shock has 6.86" of travel. The "long" one has 7.86". The shocks I bought have 10" of travel. This should more than cover the needs of the suspension.
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
Up travel is just as important as droop. Order shocks too long and you could bottom them out on a speed bump.
For your next set I would measure both up travel and droop.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Factory off my 87
On the axle tab, it was just a longer bolt to accept 2 shock eyes
78silverado
