spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
- Jun 6, 2017
- Dallas, TX
- Spanky
- C10 Short Fleet
- V8
One of the plethora of times that I had the carb off and on to fix it, I think I did something to the choke.
Its been hot down here in Texas so I havent had the need to fix it, and out of the blue, its 40 degrees.
So I will describe it has the choke is loose. I thought that I read somewhere that the butterfly should open on its own weight. So if that is true, that works. And the linkage seems to be attached to the cam correctly, as I didnt take any of that apart.
But, if I adjust the fast idle screw, it changes nothing. So it *feels* as if that is the part that isnt attached to something it should be.
I can get pics later on if need be.
