Power steering gear box
muldokken
Lynn
K1500
So got kind of an odd one, had some problems with the original gearbox so got a reman one got it installed and now when I turn to lock to the right and back to center the wheel is fine then lock to the left then back to center the wheel is off a quarter turn, lock to the right then center and fine again. Is there something in the steering gear that could cause that. No play it's nice and tight. Any ideas? Thanks
muldokken
Lynn
K1500
So I have inspected and replaced some parts a few months before I started having problems with the other box. This was not happening before the change. And even if there were worn parts they would have to be pretty bad and it would not be that consistent would it? That is why I was asking about the box.
Blazerbiker
Rifle CO
Stephen
K5, actually a Jimmy since it's a GMC
504in
Put the front axle on jackstands so that there is no weight on the tires and do the same test. This will take everything in the suspension out of the equation.
muldokken
Lynn
K1500
Ok, well talked to a builder and he said nothing in the box would create what I am experiencing. I had the tires on gravel when I was inspecting things then decided to do it on pavement, that was the key apparently. I found it almost right away. the damn ubolts on the spring packs had come loose and the driver side, box side was sliding back and forth on the spring pack. it would slide back but not forward because of the sway bar. not sure why that just showed up after the box change. thanks guys hope this helps someone else some day.
seanhatesregister
