Pick Up Headliner
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
My blue 84 Silvy had headliner,k5 had headliner with all the plastic trim pieces covered in the headliner material as well, the black truck did not have one, and the white truck I have now doesn't and neither does the cab that's replacing the white truck cab.
highdesertrange
kalifornia
mike
k30
yeah I did my dually basically the same way. only I didn't cut any wholes or trim it until after it was glue down. also I glued half of it at a time because it was so long. I also had a 73 with a factory headliner. highdesertranger
Konas new ride
Alberta
Gerald
Thats how i was going to do it. Glue half then flip the new covering over to the other side then spray and make contact.
I have six news papers to cover everything around cause i am doing this in my kitchen on the counter. Let it dry up for a while and assemble the cab.
Spray glue both on the fabric and the liner board and let set a little before sticking together.
Konas new ride
Alberta
Gerald
yup yup yup..
A SMALL hint.. make sure your spray glur is not OLD CRAP.. hahaha I get to redo it.. its not sticking well.. Yes i followed the instructions on my glue.. YES.. I realized afterwards this stuff is older then the hills.. So.. peel off the materiel and buy a new can of spray.. Thats tomorrows job while in town to get my driveshaft.. :party36:
Mike5slsg
Illinois
Michael
305 CI
How do I remove the dome light in order to take down the headliner?
Remove the lens cover, then you will see 2 sheet metal screws. Remove the screws and it is loose.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I plan on putting a headliner in my 73. What years will work if I can find one?
ben_swager
