Performance flywheel/clutch
Georgeb
Wisconsin
George
K10 Burb Z71
So Ive tried everything to remove my pilot bearing and it isn't budging at all! Ive used the hammer slide, didnt work, bread trick, didnt work, and now im left with a shot pilot bearing full of bread! Ive tried to use a screwdriver and sharpen it with the grinder and splitting the bearing. Its a little brass bearing so its generally weak, should I keep up with trying to break up the bearing? im just a little scared of hitting the crank.
You can try to tap it 1/4npt and install a grease zirk. Then push it out with grease.....
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
I have always used the grease trick. I think it would work better than bread, as bread has lots of air voids in it. Pack as much grease as you can get in there. Then use a piece of round bar stock (or something similar) that is almost the same diameter as the inside of the bearing to punch against the grease and force the bearing out. The key is to use something that fits just snug enough into the bearing to keep the grease from shooting out, but just loose enough to slide through the bearing without too much friction.
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
You will have to do it a few times, packing more grease in each time.
CSFJ
This. I've never had it fail. Hydraulic pressure is a wonderful tool.
Agreed, the grease trick works pretty well. Haven't tried it yet, but peanut butter might work even better.
There is a fancy Snap-On tool for removing the bushing, it sometimes works.
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
Peanut butter would probably work...but I wouldn't trust anything other than JIF. And if you go this route, stick with creamy. Gotta stay away from that crunchy ****.
CSFJ
I would have thought Peter Pan pb, because ...magic
Choosy moms choose Jif, and mom is always right.
Georgeb
Wisconsin
George
K10 Burb Z71
Maybe Nutella?
Rusty Nail
Rusty
350sbc
Put the hammer down!
Try asking it nicely.
If that doesn't work, pick up the hammer and cuss and threaten it.
What does the Haynes manual say?
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
Pretty sure Haynes says to pack it full of grease.
AustinDube
1976 Chevy K10 Custom Deluxe
Maine
Austin
K10 Custom Deluxe
5.7L 350
Ive finally taken the pilot bearing out! I had a 9 piece puller set but I didnt have the right sizes for it, so i had to chisel out the inner part of the bearing, then hammer a size too big off the puller into it, and got it out, although I cannot get it off the tool, atleast the most of my worries is dealt with!
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
Glad you got it out. Next time try the grease method. You'll be surprised at how simple and easy it is.
Rusty Nail
Rusty
350sbc
I like readin this kid's threads but they are ********.
Where's the pics dude?
Seriously. You have a cell phone. It takes pictures. :grd:
Use the paperclip .
AustinDube
Maine
Austin
K10 Custom Deluxe
5.7L 350
Ya i'll definately try the grease method some time and i'm trying to find out how to upload pics rn
ben_swager
