PaulCrawler78 92 Blazer
Ya I found a complete kit from trans go for 242 with a Jr shift kit and vette servo all new seals and gaskets clutches and band if memory serves me right
And $50 for the Beast. $60-$70 for the Z Pack or Alto Commercial 3-4 Cluctch pack. So you're at $370 and other Misc expenses, like filter for the bare minimum I'd consider putting in it, you're at $400. So again, at $390 exchange what are you really getting? You're getting a freshened up trans with only what needs replaced fixed. But like I said, these days, you never know. Chances are your trans has been rebuilt already once of twice in it's life. What if someone already has put the beast in it? What if it has the Vette Servo already? It may have Beast and Vette Servo and a ****** 3-4 clutch pack and why it's gone bad. Just like a chain, the weak link.... If it's not covered it needs rebuilt again and again.
That's why when I build my own, it'll have $800 - $900 in parts in it and why I have not done it yet. But if you were to buy the trans I hope to build you'd probably pay $2500 for it, maybe even $3000. I'm sleeving the input drum too, hardened input shaft, upgraded sprag, super hold 3-4 Servo, Sonnax 3-4 return springs, blah blah blah, and I do intend to tow in OD with it.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
So would I be better off rebuilding mine by myself or pay that guy to rebuild it for 750
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Wise to listen to master Yoda it would be...yeeeessssss, mmmmmmm
Jims86
Patterson,Ca
5.7 TBI
That's what I thought
Not for nuthin bro, but you are into this whole mess over twice the cost now that it would have been to fix the trans in the original project and get it smogged....not to mention the SAS you have to look foreward to, and the body work.
Just my $0.02
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Trust I know that all to well and I'm extremely pissed at myself for doing this to begin withwith
Jims86
Patterson,Ca
5.7 TBI
Dont be pissed at yourself...just learn from it, and move on.
**** the killer deals that sound too good to be true.
If you feel confident enough to tackle it and you FIL has the tools to do it, give it a try yourself. If you don't, go for the $750 and a 1 yr warranty, go for that deal. IIRC, he's at least handling the bare minimum known flaws isn't he?
Where some trans guys get to make a few extra bucks is if the trans has been previously built by a good shop and it already has the Beast in it and a Vette Servo. Those are expenses I doubt they'd be willing to tell you if it had it done before. You said this trans has been built before and you seen the paperwork. Look at the paperwork and see if they itemized The Beast and/or Vette Servo. Most of the time shops will do so on the Invoice. If not, call that shop, play dumb. Ask what a rebuild on a 700r4 in a 92 costs. Then ask what does that include. If it's not mentioned, ask if Vette Servo and Beast are normally included. If so, then you can ALMOST ASSUME your trans has that stuff already and just needs the rebuild kit and Z pack or Alto Commercial Pack. If they say NO, then you can pretty much be sure it's NOT in there and needs to be this time.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I called the trans guy that will rebuild it for 750 he is replacing the sun gear the band clutches for a z pack vette servo and he also is putting a new torque converter not a reman
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Well I got a transmission for the Tahoe for 50.00 and the guy wants to pay me to fix his exhaust that basicly pays for the transmission lmfao it came out of his rolled over 4x4 pickup that was a 1990 so I bought it hopefully it work long enough for me to rebuild mine that's in the Tahoe
Perfect !!! A 90 is a good one too. Should bolt right in. And he's 100% positive it works? It's worth more than $50 just for a core.
I won't pay that normally, but for a good 88-92 K case core with 4x4 output shaft I might if they brought it to me. The last 2 700r4 cores I bought, The guy had 2 90 model 2wd cores and I figured for getting 2 of them, I'd make the 14 mile drive, 28 mile round trip and buy them both for $60 ($30 each) which was $25 each in my book since I got 2 at the same location and didn't have to spend 2 trips in time and gas to go get them. That's the last 2 I bought. The last 2 I acquired, 87 and 89 K case 4x4 cores were FREE, one I had to pull while at work, one I had to go pick up. Normally CL price on an 88-92 700r4 2wd core is $100 and a 4x4 core K case is $125-$150. From a salvage yard, you can add $50-$75 to each price.
MrMarty51
Eastern Montana
Martin
I have a real nice turbo 350 transmixer,been setting for a while so it1d prolly needs a kit,but it is the better one,with the flat torrington bearings instead of the shims,if I lived closer I`d bring it over for You to have.just setting here collecting dust.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ya the trans has the k on the bell housing and rainbow through the top fitting also clean clean trans fluid and smells great for 50 I could not pass that up and to top it off he is gonna pay me 100 to fix his head pipe for his exhaust so I would say I got a killer deal
MrMarty51
Eastern Montana
Martin
Long as stuff do`nt start breaking,I`ve done several of them "Killer Deals" that I would have been better off paying the fifty bucks an been done witit.:nutkick::happy175:
NAAAW,I think You`ll be AOK in this deal.
southbaymiller
