SFDfirefighter
- Jun 30, 2012
- Seguin, Tx
- Ryan
- K10
Hi guys,
I just recently bought an 83 K10. It has a stock 305 with I believe a TH2004R transmission, NP205 transfer case, and a 10 bolt front and rear axle. I am currently building a 350 with a TH350 transmission which I plan to drop in place of the 305 until I can build my 450 horse 383. My plans are to put a 12" Superlift with 40" Toyo Mt's. I know that the 10 bolts will not hold up with the amount of tire I'm planning to put, and not to mention the amount of torque I plan for the 383 to have.
My question is which Dana 60 and 14 bolt should I try to find to swap the 10 bolts? If I can find a set from a 73-87, will it be a direct bolt up or am I going to have to modify them somehow? Also what gears should I plan on putting in them as well?
Any help is greatly appreciated! Also any input from someone that has done this lift will also help.
Thank-you, Ryan.
Thank-you, Ryan.
