Old77's 1989 S10 tinkering project
bluex
Spartanburg SC
C15
Check the wiring diagrams for it. If it's setup like a 88-95 GMT400 the speedo goes to the drac an the drac feeds the cluster, cruise an ecm. As long as the drac has power/ground the speedometer should work with everything else removed.
Temp an oil pressure should go direct to the cluster as well. We swapped a 350 in the 95 1500 my son had with an hei and a sniper. All the gauges still worked like factory. Just find a way to adapt the stock sender to your replacement engine an they should work fine.
A carb engine with an hei just needs power an ground to the coil to run, after starting anyhow.
idahovette
Weiser Idaho
Perry
K20-K10
Agree with @bluex . Kooper's 91 S10 700R4 is hooked to the drac and then the speedometer.... works perfectly..... Oh Sh!t that'll come back to bite me!!!!!
All that makes perfect sense! :waytogo: There's so much info out there it's kind of overwhelming LOL Sure would be a lot easier if someone who wants a project would just come buy this thing. :rolleyes:
idahovette
Weiser Idaho
Perry
K20-K10
Kooper's has turned into a kick-ass rig. Gets a lot of looks and comments, when he's out with it. Sadly, with all he has going on(house and land purchase) he has very little time to enjoy the damn thing!!!
BALLTURRETGUNNER
