bluex
- May 9, 2013
- Spartanburg SC
- Paul
- C15
Check the wiring diagrams for it. If it's setup like a 88-95 GMT400 the speedo goes to the drac an the drac feeds the cluster, cruise an ecm. As long as the drac has power/ground the speedometer should work with everything else removed.
Temp an oil pressure should go direct to the cluster as well. We swapped a 350 in the 95 1500 my son had with an hei and a sniper. All the gauges still worked like factory. Just find a way to adapt the stock sender to your replacement engine an they should work fine.
A carb engine with an hei just needs power an ground to the coil to run, after starting anyhow.
