Oil pressure sender switch and coolant sender what type of thread sealant to use since your not supposed to use Teflon so it can ground correctly
wildone454
wv
cody
dd1990
Ventura CA
Suburban 1500
Ive always used Teflon paste and tape just don't use a bunch...make sure some of the brass is showing
Carb'ed Vortec 350
Technically you shouldn't need any thread sealer as the fittings flare out/taper out. So the tighter they get, the wider the threaded area is, and the tighter the fit in the hole.
350 w/203
That's what she said.
As @DoubleDingo already pointed out,they are NPT which means they taper and the more you tighten it,the more wedged it becomes. NPT does not have a specific torque,and you don't want to over tighten it,you can actually crack things. It's just snug,plus a little but more if it leaks give it just a little more.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Gasoila is the red stuff that's usually used on fuel systems and often shows up on pipe threads on senders. However, it's not exactly in every store.
It's pretty common to use pipe joint compound that can be found in any home store.
Teflon tape is okay if not abused, as others have said. I would not put it together dry and expect the taper to seal it. Plumbers never do that, because tapered pipe thread is one of the $#itiest connections in the universe. It's the household equivalent of TTY fasteners. Getting them to seal involves TTD. Tightening To Destruction.
Don-T
Vermont
Don
I use a bit of PTFE paste but that is from decades of working with stainless steel. Use it sparingly and it will be ok.
All you need to know,how it works,and how tight,kind of a long read,but good info to know.
Don-T
Vermont
Don
zachbw55
