NP241-C, non VSS. Can I convert to VSS or no. No luck!!
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I have a Non Vss 241 T/C. For a ls swap I need a Vss on it. I have looked for a vss nose cone or what ever you call it with no luck
Does anyone have a remedy for this? or want to swap a non vss for a vss nose cone? I cant even find used ones for sale. :confused:
vr1967
Mississippi
Virgil
k1500
6.2L turbo
This is what I am doing with mine, as I can’t find the rear pieces for a passenger drop 241 (i have a driver’s drop and they are different)
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
What was the issue with the Dakota Digital VSS generator that Crispy suggested before?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Tail housing
I would go for the kit @vr1967 recommended. I did a homemade version for free but already had the reluctor wheel and sensor and got my tail housing welded for free. That kit wasn’t available when I was trying to figure it out…
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Tail housing
Got me to thinking now. I still have a driver’s drop parts 241. Wonder if I could 3d print an adapter to go in the original hole? Or machine me one out of aluminum here at work?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Just some Deja Vu here>>
2020 holy cow I forgot about that thread. That project never happened. I'm looking at doing a
6.0 with a 4l70E and a 208 since the kit VR1967 recommended works with both T/C 208-241.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Tail housing
Thats pretty cool!
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
I did install the Walter Engineering VSS on a NP208. I found Walter Engineering VSS problematic. First the signal was very weak and would only start working after I was going 20mph+. I needed to get the speed sensor closer to the reluctor wheel, so I sanded done the speed sensor holder to get it to sit closer to the reluctor wheel. It works better, now starts picking up vehicle speed around 4-5 mph but I would say's it's not perfect. Also where the VSS fits into the case is leaking oil and I need to figure out how to stop the leak. Possibly use some RTV where the o-ring seals in the case. If you go with the Walter set-up, please let us know how it goes because there is not much information out there.
Bowtie-dad
Wyoming
Brad
V35
7.4l
I have a whole 241c transfer case from an 05 06 2500 with 148,000 on it. Manual shift. I'd let the whole thing go cheap.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Wont work on a square. But thanks for offering :happy160:
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
This really sucks to hear. As far as the leak, RTV does wonders.
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
There are passenger side NP241 with a VSS out there but very pricey. There are a few on Ebay and www.transfercasesolutions.com, have some in stock.
geardaddy
st. paul mn
mike
several
If anyone is looking for passenger side drop parts with the elec. speedo (VSS) give me a call at 612-309-3999
WaterboyCrewCab
