NP205 same for sm465 and th400???
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
Ok, I’m looking at buying a 1 ton dually with a 350ci motor. It has a th400 with no reverse in it so needs a rebuild. I’d rather have a 4 speed being a dump truck and wanting a manual pto. I’ve found a complete sm465 trans, bell housing, shifter, pedals flywheel etc out of a 1/2 ton np208 truck. Will my auto 205 bolt to the 465 from the 1/2 truck?
Ben.
Probably not. The Year will matter though. An 84-later NP205 will directly interchange with an 84-later SM465 from any other application. A Pre-84 NP205 from a TH400 application will MOST LIKELY fit an 84-later SM465(you might have to shorten the output shaft). A pre-84 NP205 from a TH400 will NOT fit a pre-84 SM465 from any other application.
Itali83
Maine
Ben
Ok so the 1 ton is an 84 with th400 and 205. Donor 465 is from an 86 with the 208. So if I read that right it should? Fit?
Ben
Ben
84 is tough... it SHOULD be a round pattern NP205 with the 32 spline female input. The SM465 SHOULD be a 32 spline output shaft and therefore the NP205 should be a direct swap for that NP208.
Itali83
Maine
Ben
ok thank you. I’m looking at the truck tomorrow and hopefully buying it. Then I’ll get the details on transmission and transfer case
Ben
nvrenuf
Mobile, Al.
@Itali83 Don't forget you will need the correct 465 / 205 adapter.
'84 was still the old 10-spline/figure-8 205 in the K30.
Bah, I'm thinking backwards. Truck is th400. But either way, '84 was still figure-8 pattern 205.
MrMarty51
Eastern Montana
Martin
All I know is that the front gear and spline coupler to attach a NP205 to a TH400 is a mighty expensive item if You go looking to buy them.
Damn that combination for being rarer AND so desired
It also has a lot to do with it being the part you need for connecting a 205 to modern OD auto transmissions. You only need to turn down the index ring and it will bolt right up to a 4L80E.
Spicy
SDJunkMan
Black Hills of South Dakota
Jeff
Probably not the right thread, but since you are talking about the input shaft, I thought I would ask here. I just picked up a front shaft with gears that is supposed to be for a TH400, and hopefully a NV4500. I hope to use it on a NV4500 swap on my 78 K10. Do these fit all 205 transfer cases, or do I need to find a specific case for the swap?
Also, I have never opened up a transfer case, will I need any special tools, or are they pretty straight forward?
nvrenuf
Mobile, Al.
@SDJunkMan The 32 spline female input shafts come in 2 lengths so this will make a difference in what it takes to fit to a given trans. Also, these inputs use a bigger bearing than other versions of the 205 so the case will need a larger bore to fit this - either a factory case or disassemble and have it bored.
No special tools are required but external snap ring pliers are nice.
SDJunkMan
Jeff
I haven't picked up the shaft (get it tomorrow) so I'm not sure of the length. Should a regular automotive machine shop be able to bore the case or do I need to take it to a regular machine shop?
I happened to be checking out an auction for the estate of a old repair shop owner, a lot of 50's parts, but happened to see a box marked New 205 input shaft for a TH400, since it appeared to be what I will need for my NV4500 conversion, I bid on it. Only paid about $60 for it and some other parts, so if it isn't what I need, I'm not out much, and should be able to sell it.
I'm still looking for parts for the conversion, and the truck won't be ready for it for a year or so, so I will keep looking for a 205 set up for a 400, but will use this as a backup. I suppose it will also depend on what it will cost me to have my case machined, and what I have to pay for a 400/205 transfer case, to decide which way I will go.
does that mean a np205 from a post 84 would directly swap into a np208 from a 85-87 combo?
MTsquare
