No way this is right?
Per the sticker on the glove box, MX1 automatic transmission, so a 3 speed I believe
Well, considering how much other things have been changed, I don't think I would trust the sticker. If they took the whole drivetrain when they got the TBI motor, they might have swapped to a 700R4. It wouldn't have a 4L60E or 4L80E since you don't have the wiring or computer to support that. Take a picture of the trans pan and someone should be able to ID it.
Kevin
C2500
Good idea I’ll take a look at it tonight
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
That's what I was getting at.
Since it's a tbi motor, I'm gonna take a guess to say there's probably a 700r4 behind it (4 speed automatic)
Yeah PCV definitely needs rework. One side should have a PCV valve at the front or back of engine with the other valve cover having a breather at the opposite side of the pcv. Like my PCV is in the driver side front of engine(Front being by belt drive), then my breather is on the passenger rear(rear by the firewall). Of course, the PCV needs to be hooked up to the carburetor. Usually the front of the base of the carburetor is the inlet.
Kevin
C2500
Looks like is is going to be a TH 400.
It has 13 bolts and the shape seems to resemble the TH400 shape. Do you guys agree?
The pictures don’t really do any justice...
78C10BigTen
pennsylvannia
C10 BIG TEN
It appears to be... im not 100% but i can sure tell you its not a th350.
Vbb199
Salisbury NC
Vince
That is a 400 I do believe.
Guess the PO just left the trans and put a tbi motor in.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Yep.
That 'gap' on the mating of the carb/intake doesn't bother me, many are made to mate to multiple carb to intake combos.
There are a couple visible vacuum issues in those pics though, ie open lines off valve cover, zip tie holding something not made for vacuum cap.
Raybo135
Arvada, Colorado
Raymond
K10 Silverado
I personally think they have the Valve covers on the wrong side. The breather hose should be on the rear of the passenger side and the PCV should be on the from of the driver's side cover. With the original style air filter, there is a connection for the hose on the passenger side to go up into the side of the air filter. And the PCV would go into the carburetor on the front. As you can see by pics of my original 400, the PCV is on the Driver's side and the Oil Filler is on the Passenger side.And the Breather hose would attach to the Air Cleaner on the side.
Kevin
C2500
I personally think they have the Valve covers on the wrong side. The breather hose should be on the rear of the passenger side and the PCV should be on the from of the driver's side cover. With the original style air filter, there is a connection for the hose on the passenger side to go up into the bottom of the air filter. And the PCV would go into the carburetor on the front.
I thought about pulling the covers off to put a fresh coat of paint and cleaning off all of the old gasket sealant that is around. Before I do that I will look into this issue some more.
Thank you for your input!
89GMCJimmy
ivan
It depends are you trying to set it up as the 1978 or set it up as the newer engine was stock?
89GMCJimmy
ivan
This is a stock 1989 350 TBI set up, PCV is pass side going into front of TB. Drive side has vent going into riser between TB and air cleaner.
89GMCJimmy
ivan
I'm not positive but I believe your Brake Master Cylinder is off a newer vehicle too. My 78' Jimmy had an iron reservoir.
Odis
