No way this is right?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I'm not positive but I believe your Brake Master Cylinder is off a newer vehicle too. My 78' Jimmy had an iron reservoir.
I think you are correct.
Overland Suburban
Estacada Oregon
Tracy
Suburban
5.7 tbi
Does it run? Looks like someone tried a swap and gave up on it? Hopefully the tbi distributor has been swapped out
Tracy
89GMCJimmy
ivan
Jimmy
Tracy
What would you swap it out for? I'm running stock on my 89' TBI, Have you had success upgrading?
Overland Suburban
Estacada Oregon
Tracy
Suburban
5.7 tbi
Scoots, the OP has a TBI engine that has been changed over to a carb that apparently won't run. The TBI distributor is computer ran and wont work with a carberator. If your engine is TBI and hasn't been swapped you want to keep the distributer you have
89GMCJimmy
ivan
Jimmy
Excellent
Thats a cheap easy upgrade
Thanks:Big Laugh:
F1r3truck
