No power to injectors along with no power to pin A6 on ECM and no SES light 1987 R10 305 TBI
gxrardo
Lexington NC
Gerardo
R10 Silverado
Hello this started with no power to injectors then I checked ECM pins A6 B1 and C16. B1 and C16 have constant 12V but A6 has no power key on. A few things to add I jumped B1 to A6 and the SES light came on and I got code 34 and power to injectors but not grounding ( I used a noid light).
ECM I fuse is good and receives 12V and I have changed the ignition switch. Where could the issue be?
gxrardo
Lexington NC
Gerardo
R10 Silverado
Update: After going back to check for pulsing with B1 and A6 jumped I realized I had the ALDL jumped and took it off and injectors pulse. But still doesn't solve my primary issue of A6 not getting power.
K5BEAST
