No power at all, zero lights, guage lights, or anything else. Any help wld be great.
87SQRBDY
Fayetteville, NC
Josh
5.7l 350
I have a 1097 Chevrolet R10 Silverado with a 350 5.7 SBC and the starter went out, so I went to replace it with a Powermaster mini starter. Once I got it back together I tried starting the truck, but got no power at all.
I read through a lot of posts and didn't see one like this. My multimeter reads 12v at the battery, starter and alternator so I have no clue what to do. Oh, ignition switch is new too. At the end of my skill set and dreading having to take to a shop.
Any help or advice would be greatly appreciated.
On the OEM starter there is a large lug where the positive battery cable is connected.
- On that same lug there is also a red wire (at least 10 gauge ) with a fusible link. This wire runs up behind the engine, through a protective metal tube, and then over to the power junction next to the master cylinder. This is the main power feed to the fuse panel.
- there is a second wire with fusible link (10 gauge? ) on the starter lug and this wire runs up behind the engine, along the top of the valve cover, and connects to the alternator BAT terminal. This is your charge wire.
I think you forgot to connect one of the smaller wires, or somehow created a short and it burned the fusible link.
87SQRBDY
Fayetteville, NC
Josh
5.7l 350
75gmck25, thanks for the reply and I got power back. Had to hook up both sets of wires to the same lug, not separately. Only issue now is a whining sound when I try to start the truck. Most likely not close enough or another issue that'll take me forever to figure out.
Dleslie212
Phoenix
Dustin
5.7L 350
Did you install a shim on your starter? If so you may want to remove it and try again, sounds like the starter is too far away from the flywheel
87SQRBDY
Fayetteville, NC
Josh
5.7l 350
Dleslie212, apologies for the late reply. So far everything is good to go. I just don't like how the new mini high torque starter still acts like my old OE style. STll have to keep turning the key and waiting for it to turn over,, but so far so good.
justinlee
