Newbie Transfer Case Identification Help
highdesertrange
kalifornia
mike
k30
did I mention I hate slip yokes on 4x4s. put a fixed yoke on it and be done with it. highdesertranger
jastewart25
Louisiana
Julie
thank you all for your help.
i finally found an extension housing in chicago.
MadOgre
NA
NA
NA
NA
NA
Take it to a shop preferably a gear shop and have them press in a new bushing for you. Its just worth the $50 not having the hassle. Buddy probably broke it in the first place trying to put one in himself.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I have a slip yoke tail shaft housing for a 205 I took it off and put a fixed yoke on
that's what I recommend you do but if you end up needing a tail shaft housing I have one
jastewart25
Louisiana
Julie
appreciate it. sadly, i purchased one already. i'm not mechanical at all but learning.
could you explain what the benefit of changing it to a fixed yoke would be? i'm not even sure what it does.
thanks!
jastewart25
Louisiana
Julie
the one i found in chicago was hot tanked with a new seal and bushing included.
thanks for advice though.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
this is a fixed yoke 205
it is stronger
jastewart25
Louisiana
Julie
it is stronger
nice. thanks. i'll look into that in the future.
i just picked this truck up from a po and it needs a good bit of tlc so i have to prioritize for sure.
a good test in patience.
Gsub
Belgium
Gert
Suburban C10
TJONES360
