Matt Buffington
- Apr 8, 2020
- Maryland
- Matt
- Chevrolet Suburban 1500, 4x4
- 5.7 L
Hi Everyone!
I have a 1990 Suburban I'm building as an overland/field vehicle. I am going to have a number of lights, and to power them with the car off, I'm installing a second batter under the hood. I have a solenoid isolator splitting the two batteries, and inline fuses between both batteries and the solenoid. With it all wired in, everything seemed fine. When I went to start the truck, the fuse between the solenoid and secondary battery blew! Further, while the solenoid line to the starter battery was still connected, the truck appeared to have no electricity; once the solenoid was disconnected from the starter battery, and factory circuit restored, everything was fine again. I have checked the grounding continuity at the second battery, and all that appears to be very good. All wires are 4 AWG, and I checked that the solenoid appears to be working in acc-on position. What should I try next? Any ideas of what I have done wrong here? Thanks so much for any help you can provide!
