New here. Not to building or wrenching.
Jeramie
Watson Oklahoma
Jeramie
Looks like I will be needing some rust repair panels. Inner rocker on driver side is rotted by the seat and there is some rust in the seams around the driver kick panel. All the supports look good and only the passenger side floorpan has any rot. It's pretty thin in a couple spots. For this winter I'm going to POR 15 the floor and just deal with it being loud and not as warm as it should be. Vice wasting money on sound deadening and carpet to take all back out in 4 months. Lol.
1973c10
Don
Welcome
Jeramie
Watson Oklahoma
Jeramie
Cut out the rust on the cowl yesterday evening. Will cut a patch panel out of the old cab and weld it in when I get another dry day that I get off work before dark. Or Saturday.
Jeramie
Watson Oklahoma
Jeramie
This was caused by failed seam sealer. Leaking into the heater box and onto the passenger floor pan. Rotting it to the point where it too needs replaced.
Jeramie
Watson Oklahoma
Jeramie
Someone in the past used blue RTV to seal it then painted it over. Pressure washer reveales all.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Welcome from Texas nice looking project
86 SCOTTSDALE
Oakham MA
Armand
Welcome from Mass. Great project, I had same issue with fire wall resulting in work on floor and rockers but all is well now. Good luck.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Welcome Edmonton Alberta Canada
Jeramie
Watson Oklahoma
Jeramie
Got new radiator, headlight switch, wiper motor, and ignition switch today. Hopefully I can start working on installing the new painless performance harness tomorrow after work.
GorillaHumper
