Need help with Parking Brake cable routing on my 84 K20
chopperroxie
Chalfont, PA
Corey
Does anyone know the years that the backing plate had the hole where the parking brake cable used tangs to lock it in as opposed to the dual plate with the 2 bolts holding it in. I have the dual plate but all the parking brake cable that I'm seeing for sale all have the locking tangs?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Looking at Rockauto 1983 is the last year for the 2 bolt style for the most part. There are a couple of applications for 1984. I put the GM part number into Summit Racing and most are for 3/4 ton 2WD with 11 rear brakes. The K20's only specify the cable length, not the drum size.
You can still get 13" backing plates for a tang style cable (13" x 2.5" brakes). GM 14056175 - left; GM 14056176 - right for about $60-70 each.
https://www.summitracing.com/parts/ado-18p152/applications/year/1984?page=3
chopperroxie
Chalfont, PA
Corey
Thanks @Craig 85 , I think I may have to do that.
I'm thinking my rear is not the original one. From all indications, it's a JB7 but I think a different year. Is there any way to verify?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
There are stampings on the axle tubes and on the ring gear. I couldn't find a reference for dating the axle tube, but I'm sure there are. Here's an example of the ring gear. This is for a '70 Chevelle.
GM part # 3862526
10 41 = 4.10 gears
3 70 = Manufactured March 1970
chopperroxie
Chalfont, PA
Corey
@Craig 85 , I finally got around to getting the right cable from LMC. I have the cable from the right side going over to the drivers side and I have the equalizer. I can't for the life of me figure out how this cable assembly works though. The front cable looks like it goes all the way from the pedal through to the left rear. The right is screwed into the equalizer. What pull on the equalizer to activate right rear?
Thanks much for your help
Corey
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Stepping on the parking brake pedal pulls the Left directly. There's no adjustment. I believe the basic way it works is the R/R engages fist, which causes the equalizer to stop, then the L/R is pulled. I'm still fiddling with mine. I bought a longer than stock cable to replace my L/R to accommodate the lift, but I think it is throwing it off and making the brake cable go almost to the floor.
Dorman makes these cable tensioners if needed. That way you don't have to pull everything apart or replace the parts you have.
chopperroxie
Chalfont, PA
Corey
Oh that's cool, I think I could use those tensioners, thanks.
I still can't figure out how the Right Rear gets activated. It's attached to the equalizer by the nut, but it doesn't look like the equalizer will move at all. I'm so confused, I keep staring at this picture from the LMC Truck website and I can't make heads or tails of it.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I'll try to explain it by the numbers. Maybe that will help.
You step on the parking brake pedal and it pulls cable #1 and equalizer #7. Cable #3 will also start moving because it it fixed to the frame near #4. Simultaneously, cable #2 starts sliding forward until all the slack is taken out. I believe the right brake will lock first (so long as you have the nut adjusted correctly). This will stop forward movement of #7/cable #2 and start applying the left brake.
Make sure your rear brakes are adjusted correctly. Any extra slack in the brake shoes will cause delay of the parking brake engagement. If you do need the Dorman part, it would have to be installed somewhere on either side of #5 connector.
chopperroxie
Chalfont, PA
Corey
Thanks so much for the explanation. Only thing I don't get is, how does the Cable #1 move the equalizer #7. It looks like the #1 cable just goes all the way through the equalizer without attaching anywhere except the left rear brakes. It looks that way with your photos too. What am I missing?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
This is the left rear hub with a 14 bolt FF. When you step on the pedal, you are taking up the slack in the spring with the rear arrow. At the same time the equalizer is moving forward. I believe the screw/bolt from the right side attached to the equalizer creates a stopping point for the equalizer bracket because the right side spring is fully compressed spring (red arrow). The system then starts pulling the levers marked by the yellow arrow and engage the parking brake.
BALLTURRETGUNNER
