Need help - replacing spotlight in driver's pillar
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Unity lists one of their longest shafts for the squares:
Yes, the mounting holes may be in the wrong location. Also you may not have the correct mount. Should be number 27. It will be cast on the underside of the mount. The Unity site will also let you print out the mounting template for some of the mounts, but #27 is not one of them.
I am making the assumption, that you have the Unity brand light. If you need the template I am sure I have a copy I could send you.
MANY,MANY thanks !!!
I will check everything tomorrow after the sun rises and it warms up enough to hobble outdoors.
We're having a cold spell for a couple days here.
But it sure beats running the big generator so we can have the cooler run all day.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
PM sent, thanks !!!!!
