My 86 454 Conversion to Propane / Gasoline dual-fuel
kapitein
Netherlands
Alex
C20 Suburban
For those interested, heres some brief details on the recent conversion we did on my 86 454 Cali-emissions C20.
This was a voyage of discovery, often finding very weird 'stuff' that previous owners had MacGuyvered there way around.... typical for a 40yr old vehicle I suppose!
So, brief details! Where did we start? 86 C20 454 with 69k miles. From the look of everything, we are 99% certain this engine had never been open before. In the first stages of taking things apart, the carb and throttle plates looked really reallt bad, and we were worried about what we would find deeper down. But actually in the end, the internals all looked really good. The cam in particular looked peachy for the age and miles.
What did we do?
IMPCO 300A performer propane system with a 100L ring tank in place of the gasoline tank.
Custom 20L emergency/reserve gasoline tank, placed just above and infront of the rear diff against the floor of the truck
Edelbrock AVS2 650CFM carb
Edelbrock performer intake
Comp cams mild cam shaft.
Edelbrock valve covers
Hedmann ceramic coated long tubes
Custom exhaust with H-pipe and Flowmaster 40s
Electric fan conversion, with ability to run-on after ignition off.
Accel plug wires
NGK plugs
General under-hood tidy up and crap removal. Cleaning, degreasing and fault-fixing
Mini-starter (cool little thing)!
Yukon diff cover with new oil
Why a IMPCO 300A and not a 425? Because I still want the option to run on gasoline in emergencies. The 300A is the system to use if going dual-fuel. The higher capacity 425 is more suited to pure LPG motors.
The motor is tuned to run on LPG and starts/performs faultlessly. It will run and importantly also start on gasoline (retained electronic choke on minimal settings), but it doesnt run as nice as propane. This is a choice, im going to run 99% on propane, so thats what we have tuned for.
And lastly, why propane? Well im in Europe... 91 gasoline is expensive (always hovering around $9-11 gallon USD equivalent) 93 (ethanol free) is even more expensive. Propane is literally 60-75% cheaper depending on where you fill up. Its plentiful here with no supply issues. It runs clean and is cheap. So why the heck not. Set up correctly (like mine is) it runs just as nice or nicer than gasoline.
So there we are. Pics below!
Where we started, rough!
Shiny new parts arriving!
kapitein
Netherlands
Alex
C20 Suburban
Old cam looked great for age and miles!
Intake valley cleaned up well!
Header install wasnt without challenges. Chassis in the way!
kapitein
Netherlands
Alex
C20 Suburban
Custom 20L emergency fuel tank:
Chassis cross members needed to be slightly notched for the 100L propane ring tank.
kapitein
Netherlands
Alex
C20 Suburban
Custom brackets for the relay system and propane condensor. Condensor is mounted longtitudinally for better performance.
Work in progress:
Done:
Accel plug wires going on:
kapitein
Netherlands
Alex
C20 Suburban
Propane filling port:
Painting and cleaning as we go:
Custom little coolant overflow bottle:
Propane controller in the interior:
kapitein
Netherlands
Alex
C20 Suburban
The finished job:
And the electric fan :)
olnick
Milford NH
Nick
c15
1982 350 4 bolt mains
Looks great! Nice clean install!
Back in the old days 1980's The City of Nashua NH was doing a test of alternate fuels for vehicles. My truck a Ford F250 was selected for the Propane conversion test. If I recall correctly the "Impco" injector was also used, the injectors were left in place with a toggle switch to select what fuel to use. During the conversion it was mentioned that the octane of propane was 190! With that being said the vehicle maintenance shop upped the timing 5-8 degrees. The truck ran like a champ.
Not switching over to the gas option as the LPG was very reliable and efficient, there was no need to. however at the end of the study it was found that running only on LPG caused all of the injectors to seize up and were NO longer operative. This was after 2 years of running on LPG and nothing else!
I think you will be totally pleased with the LPG conversion another plus, the oil NEVER gets black dirty as with gas operation.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Doesn't propane burn very hot? Just curious if it effects engine temp and cooling needs.
vintovka
or
vin
Nice job. parts prices here make me choke can't imagine them in Niederlande plus shipping!!!!!!!!!!!
fisherbobbitt
