1987 GMC Jimmy
Automobile Hoarder
- Jan 23, 2016
- Mississippi
- Jesse
- V1500 Jimmy
I put three gallons of gas in it, and installed the fuel pressure relay (took it out to test the electronics out). Heard no pump and got no start. I sprayed a little starting fluid into the throttle body, and it popped off for a sec so it looks like once it gets fuel, it’ll start up. I got just the pump, a strainer sock, and a filter. Part of me wants to just cut a hole under the seat and do it, but if there’s rust, and I have to have the tank rodded out, it’ll have been for nothing. I also made sure the pump fuse and relay were good. Would there be an access panel on this? Probably not...
I checked fuses. What a weird setup but whatever. You have to take this little cubby out of the glove compartment, and there it is. At this point, the instrument cluster, the turn signals, and the horn are the only things that don’t work. Climate control does work, at least partially. Anyway, all the fuses are all good. I have not been able to locate the turn signal flasher yet. Hazards work, and the clicking sounds like it’s coming from somewhere on the passenger side. Horn relay clicks, but there’s no beeping. Maybe the horn just isn’t getting the juice, or the wire got loose. I have no clue what the deal is with the cluster.
