Mounting to interior sheet metal
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Il check into that, clean truck too, what are your switches by the tray for? They look factory
Most likely a suburban with electric rear window and rear heat or a/c. My suburban has those two options and I have the same switch. There’s different variations though, my 79 has a switch there for the dual gas tanks.
yevgenievich
Place
Name
Year
Model
Size
Thanks, Suburban switches, rear ac, rear window, rear window heater. Non factory switch is for torque converter lock up override
Snoots
Roger
Jimmy Sierra
350 w/203
Gdub
Los Angeles
George
Something like this is a tool for every size but they have small installation tools that are like a couple of washers and nuts on some all thread but in my experience once you use nutserts you will find a desire to use them a lot more and justify buying the tool...
https://www.amazon.com/dp/B003TODXQ...TF8&colid=3LUTBGO9U3GNX&coliid=I14SL9B1RT2U29
This one works really well in areas that don't give you room to swing the handles of the manually operated tool. I've used it at least 10 times on my truck for 1/4-20 nutserts/rivnuts (same thing) in various locations:
https://www.amazon.com/dp/B01JBO58FM
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Daddy Likes!!!!!
Obwonkonobe
AZ
Ethan
C10 custom deluxe
That's dope, now if only I had 100 bucks.. :D
rpcraft
Robert
Jimmy
LS 6.0 364 CID
I'll find the money. One thing I like about that unit is its got a low toolbox footprint too. I've yet to buy a tool, last time I installed them I used some allthread, and nuts with a small torrington washer and it was a PITA to mess with. I got it done but I swore I'll buy a tool before I go down that road again.
CSFJ
I did it the way you just described when I put the armor on my jeep tub. and your right about it being a pita. When I was at the dealership, we had one for the smaller riv-nuts that was set up like a the Marsen type rivet tool. That worked pretty well.
rt66paul
California
paul
1991 suburban
I think it would depend on what you are mounting. A fire extinguisher, speakers are one thing, a grab handle or a seat is another.
A grab handle should be good for 500 lbs, your bubba buddy + G forces holding on to a bar should not tear out the sheet metal.
A fire extinguisher holder or speakers would never have those forces(if it did, it would be in a wreck situation)
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Very good point, for the grab handles Il be investing in nutserts
rpcraft
Robert
Jimmy
LS 6.0 364 CID
While we are discussing the idea of this, can anyone tell me if they cab top is double walled or is that a single thick piece of metal on the top of the cab?
75gmck25
Northern Virginia
Bruce
The top of my '75 cab is dual wall, and there is open space of as much as an inch between the two metal layers. On trucks with roof mounted clearance lights I think they run the wiring through that space between layers.
Bruce
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Bruce
yep, good reminder. I had forgotten about that. Thanks. I was looking into a way to mount an overhead console from another vehicle and was thinking about using rivnuts to go about doing it, for the frame work.
SDJunkMan
Black Hills of South Dakota
Jeff
I wouldn't trust nutserts with a grab handle, unless ther are just mounted above the doors for getting in and out of the truck. If it's an Oh **** handle and you are mounting it on the passengers side of the dash, put a piece of flat bar or something similar behind the sheet metal to secure it to.
SDJunkMan
Jeff
I would be interested in what you come up with. My 88 has an overhead console (it's a conversion truck), and I would like to make one for my 80 K20.
truck86
