monojet i6 drinking gallons at idle
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
If you know the fuel pump is wrong the distributor is swapped and the carb is junk then you're just here to get the magical "nothings wrong with it" answer. Someone said they got the their rebuild kit at Napa for your carb in your question, you kinda just glanced over it then swapped another not correct carb. When you haven't touched anything else. I understand you're now waiting for parts, but it's not gonna magically get better by itself.
Also a truck body without extra modification will not work on a suburban frame. The frames are definitely not the same. Then it wouldn't look right either.
Not trying to be an ass but probably coming off as one and that's fine. If you're here to just update that's cool, but make a build thread. If you're trying to get answers then stay in a thread like this. Just confusing if you want help or just chatting. Seems like you don't want help.
Don't matter to me lol
Carb'ed Vortec 350
Keep at it, looking forward to seeing this one fixed and driving with I6
cartercarbaficion
Cusick WA
matthew
i said this frame looks just like the 3/4 frame under the suburban as in its a heavy half truck.
i swapped carbs because the monojet litterally corroded a hole from the bowl to the throat from it sitting with mud duabers and water. i also couldn't find a monojet for what i deemed a reasonable price with an automatic electric choke(60 dollars and it still needs a rebuild and shaft seals is just unacceptable. plus most of the time irs the wring choke and thats another 30 bucks) the distributor is original to the motor since i litterally said this truck has an overdrive automatic which only started happening around the time they went to hei style distributors on the 250. ive since found out the cab is a 77 and most of the rest is random parts off of other squarebodys of various years. the drivetrain being the newest parts.
if i wanted to spend the money on the correct original parts i would be 3k into the truck to get it right since i would need to finish the engine swap somebody started already, plus the wiring and setting the brakes up properly (i have 2 different drums on the back. my solution is a different rear axle since i don't want the semi floating anyway)
cartercarbaficion
Cusick WA
matthew
i will do my best. currently debating on finishing the previous owners efi swap and if the i6 is gonna be strong enough for the 4wd. my guess is not really but it just has to get places and occasionally help trucks and tractors out of ditches and carry tools and 120v power to run bigger tools (i picked the inverter up from a van conversion 30 amps should be fine. im looking for a big 140 amp rv alternator to make an aux mount for and run the exciter on a toggle)
How were we supposed to know the distributor was correct until post 18,you literally said on your previous post you put on a distributor that looks just the one on your 454,not I put on a distributor from a 198? I6. What year is your motor? What year is your distributor?And the argument that the correct carbureator was too expensive,doesnt mean the random carb you put on will work as is.What did your replacement carbureator originally come off? Have you checked compression,that's step number one on a mystery motor,before they even run. It's not my first ******* rodeo either, I have decades as a career in this game. And @PrairieDrifter didn't find out until post 15 this wasn't your first ******* truck.
cartercarbaficion
Cusick WA
matthew
i didnt put the distributor on. I said this is a 80s i6 someone put in. more accurately they swapped the 77 cab onto that frame. and im referring to the style of hei cap since theres actually more than 2 gm used.
carb is off a ford 256 from a 76? mercury monarch i had bought last year and gave up on (you cant fix a pretzel thats rusty)
compression is amazing at 180 psi for cylinder 1,4,6 and ~172 for 2,3,5.
i knew it ran a few years ago..well a few being 10 but it was under a rotting shed a tree took out so at least it was covered til last year. i spun the oil pump with a drill before i even cranked it over so hold your horses.
it ran ok minus the being almost flooded out and now its just not pumping fuel again so im throwing that mechanical pump in the trash (i have a factory cover plate and a different pump for it to keep the dirt out) and just putting a edelbrock 5 psi max electric pump on so i can actually use the factory gas tank i removed and cleaned 3 months ago when i actually picked it up.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Strangers wanting us to fix their truck through the internet always get so defensive, I'll never understand it lol.
Like we're calling em stupid at every turn. But in reality we're trying to piece an invisible jigsaw puzzle of parts and hackery together, with no pics and basically no explanation or description of said parts and problem. No history or background. No testing either. But I changed a part I thought was bad! But it didn't run better, so now I know this other part is "bad" too and I'll change that also! Most would call that the parts cannon. Or in the "pro" world, a parts changer not a technician.
Bit my tongue as much as I could lolol.
kobedemello
