PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- 84,79,77,76,70,48
- Suburban k10, bonanza k10, k30, k20, c10, gmc 1/2ton
- 350, 350, 350, 350, 350, 350
If you know the fuel pump is wrong the distributor is swapped and the carb is junk then you're just here to get the magical "nothings wrong with it" answer. Someone said they got the their rebuild kit at Napa for your carb in your question, you kinda just glanced over it then swapped another not correct carb. When you haven't touched anything else. I understand you're now waiting for parts, but it's not gonna magically get better by itself.
Also a truck body without extra modification will not work on a suburban frame. The frames are definitely not the same. Then it wouldn't look right either.
Not trying to be an ass but probably coming off as one and that's fine. If you're here to just update that's cool, but make a build thread. If you're trying to get answers then stay in a thread like this. Just confusing if you want help or just chatting. Seems like you don't want help.
Don't matter to me lol
