Mechanical fuel pumps
DavesJimmy
USA
Well heres a list of parts i purchased from lmc to hopefully help with the conversion. All parts where for 1987 chevy/gmc.
DavesJimmy
USA
Ok i got the parts in! Which of these connections on the sending unit do i use? Im guessing just the 2 with the threads.. and the other's cap???
73c20jim
Tombstone, AZ
Agree. Keep the return line. It also recirculates the fuel. Keeps it cooler.
DavesJimmy
USA
Well finally got the Holley sniper efi system installed. New 87 tank, 87 sending unit, walbro in tank pump. Now the problem... my fuel pump wont shut off even when keys off.. grey to power. Purple to sender. Black to ground.. any thoughts?
Maybe a bad relay? oh yeah and it wont start just cranks..
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The relay is definitely supposed to prevent that from happening. I’ve never known them to fail with the circuit closed, just open. I have read that can happen, though.
anderson13r
