ls3 swap bell housing w/pictures
thecrow71
america
terry
k20
I am swapping a ls3 into an 85' chevy k20 suburban w/ muncie465 manual 4sp and for the most part the bell housing bolts line up but not all such as the 12 o'clock position does it matter if they dont all get used?
thecrow71
america
terry
k20
Thanks squaredeal91 I think there’s a couple other two to be exact that don’t particularly lineup or even have a spot for them
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
You should have 3 on each side if memory serves me.
thecrow71
america
terry
k20
These are the ones I’m curious on
squaredeal91
Greg bush
1991 SB
Wow. I guess I don't know what an ls3 is lol.
How many holes actually lign up? 3?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
thecrow71
america
terry
k20
Five of the six holes on the bell housing lineup with the engine
squaredeal91
Greg bush
1991 SB
Looks like you might be able to fabricate a holding bracket using that top hole. Can probably carefully flatten a spit in the bell housing and press it to the block to keep it from vibrating and flexing.
thecrow71
america
terry
k20
Yeah thanks I could probably have somebody aluminum shop weld something on the top as well
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Bowler transmissions can help you with all your questions about everything.
Make sure you have the correct flywheel for your swap.
stickshiftsteve
