MannyDantyla
- Jan 13, 2015
- Lawrence, KS
- Danny
- K10
- sbc350/sm365/np205
I made a 400 mile round trip drive on my 83 chevy 4x4 this past weekend, with a stop at an Off Road Vehicle area to do a little 4 wheeling. When on the highway, the truck would shake if I drove over 65 mph. After the off road fun - which included a good deal of bucking and bouncing and vroom vroom - and back onto the highway, the truck started making a loud squealing noise.
The noise is a loud metal squeal. Like a bearing went bad. But it would ONLY make the noise when the vehicle was coasting to a stop, with or without the breaks applied, with or without the clutch engaged, and with our without the tranny in neutral. If it was slowing down, it was making the noise. And the loudness is in sync with the speed of the wheels. When moving really slow, can hardly hear it. When moving fast, it's really loud. But still, it's only when slowing down.
My first thoughts where, either wheel bearing or throughout bearing. But it didn't matter if the clutch was engaged or not, and it didn't sound like the videos on youtube of bad wheel bearings. And the fact that it only makes sound when slowing down is strange....
So I thought I would check out the u-joints. I get under the truck and grab the axle and try to move it around to see if the u-joint had any play in it. It didn't move, but the yoke did! The yoke totally can wiggle a few millimeters in any direction, and there's actually 1 or 2 millimeters of daylight between the yoke and the differential body. Oil is actually dripping out a little.
So that's got to be it. Hopefully all I'll need to do is remove the u-joint and tighten the bold behind it that bolts the yoke to the pinion. Will inspect the bearing and seal too and likely replace them. God I hope I don't have to replace the yoke and/or pinion, I can't afford that right now.
Then I looked at the other end of the driveshaft and, surprise! An even bigger gap between the yoke and the transfer case. But it's on there pretty solid, no play in any direction.
That's not normal, is it?? You can see a ring of oil/grease that has been splattered onto the floorboards.
What should I do?
The axle is not stock. This chevy 4x4 used to be a 2WD C10 according to both the VIN number and a carfax report. So it was converted to 4wd. And I believe it used to be an automatic because there's the P-N-D-R indicators on the dashboard. Now it has a SM465 and NP205 transfer case. The 305 was also swapped for a 350 and 35" mud tires were installed.
Do you think it's possible that the SM465+NP205 was the same length as whatever auto tranny it used to have, so the PO didn't replace it with an axle that mates with a transfer case not an auto tranny...
I'm not going to replace the driveshaft if I don't have to. I wonder if I can just install some oil seal in that space between the yoke and transfer case. Or maybe one is supposed to be there and it's missing.
What should I do?
